ArcGIS Hub - JSON Stacked Bar Chart
1885
04-29-2020 12:38 PM
HaleyDockray
I am brand new to JSON so I may be missing something super simple here. I am struggling with my code that is supposed to generate a stacked bar chart with three different data sources. I want the x-axis to show the dates and the y-axis to show the count for each date (I have excluded the url and renamed the datasets):
  "type": "bar",
  "datasets": [
      "url": "Dataset1",
      "name": "Dataset1",
      "query": {
        "orderByFields": "FID_count DESC",
        "groupByFieldsForStatistics": "Date",
        "outStatistics": [{
          "statisticType": "count",
          "onStatisticField": "FID",
          "outStatisticFieldName": "FID_count"
      "join": "Date"
          "url": "Dataset2",
          "name": "Dataset2",
          "query": {
            "groupByFieldsForStatistics": "Date_",
            "outStatistics": [{
          "join": "Date_"
              "url": "Dataset3",
              "name": "Dataset3",
              "query": {
                "outStatistics": [{
              "join": "Date"
      "series": [
          "category": {"field": "Date", "label": "Date"},
          "value": { "field": "FID_count", "label": "Dataset1"},
          "source": "Dataset1",
          "stack": true
          "category": {"field": "Date_", "label": "Date"},
             "value": { "field": "FID_count", "label": "Dataset2"},
             "source": "Dataset2",
          "stack": true
             "value": { "field": "FID_count", "label": "Dataset3"},
             "source": "Dataset3",
          "stack": true
No matter what adjustments I make to the code it never seems to work and I always get "There was an error in chart generation".
I feel like this should be super easy but I am about to bang my head against the wall!
HaleyDockray
I actually got this figured out by posting on another site...
The issue was the join. I needed to use the same value for each join function.
HaleyDockray
