ArcGIS Hub for Organisation Users only
1227
09-11-2019 05:11 AM
BenasPekarskis1
Are there any resources in regards to how do I limit access to the data within arcgis hub only to the people that are in my organisation?
What does Index data button do?
Regards,
Ben
HemantAngarkar1
By access to data if you mean accessing data from within the Hub Site/Initiative, then this might help;
Share a site—ArcGIS Hub | ArcGIS
However in my experience, in order to share data to open data site/initiative it should be shared publicly hich is then shared with Open Data dedicated group. Which makes it available for public (someone knows how it can be searched and accessed).
HemantAngarkar1
Sorry forgot about Index Data button. So Open Data registers all the items shared with all the open data groups in the organization and groups taken from outside the organization. When it does so, it builds an Index which updates automatically whenever an Item is shared with or removed from Open data group. If for some reason this index is not updated and you can not see the changes made (Sharing or unsharing an Item) in Data page or in Hub Site the you can rebuild the index manually by hitting the Index data button.
Data manager—ArcGIS Hub | ArcGIS
