aquiring a tool
4188
01-05-2016 07:14 AM
inbarchashmonay
hello,
i am trying to use image classification tool on my free trial arcgis, but the button appears in gray and is not avialble
is there a way to use this tool on the free trial version?
thanks
inbar
DanPatterson_Retired
Go to Customize, Extensions menu, and toggle on the Spatial Analyst extension (assuming you registered the extensions).  Select an image and the tools should be enabled (at least for my installation and arcmap 10.3.1)
inbarchashmonay
thanks!!!
בתאריך 5 בינו 2016 17:35, מאת "Dan Patterson" <[email protected]>:
GeoNet <https://community.esri.com/?et=watches.email.thread> aquiring a tool
reply from Dan Patterson
<https://community.esri.com/people/Dan_Patterson?et=watches.email.thread> in *ArcGIS
Open Data* - View the full discussion
<https://community.esri.com/message/578480?et=watches.email.thread#578480>
RebeccaStrauch__GISP
In desktop, under the Customize Toolbar, Select Extensions and make sure it us checked.  ArcMap and ArcCatalog act independently, so you will need to check it in which ever software you are using at the time.  Since all the extensions come with home use, if it was me, I would just check them all on.
