The only available panels are named general, model nugget, model#1, 2, 3, lag etc. How can i access the settings for semivariogram plotting? Thanks in advance for any pointers!
Please share a screenshot or try and see if you can resize the window that should be above the horizontal line above the 4 buttons on the left. See image below.
[ATTACH=CONFIG]29627[/ATTACH]
I attached the screenshot. Although mine is Arc 10.0 but the help documentation regarding view settings in semivariogram is identical to that of 10.2 so there should be a view settings tab. I am puzzled as to where it is. I have editor license as well. Thx, [ATTACH=CONFIG]29630[/ATTACH]
thanks a lot for your tip. Yes double click the pointed area solved the mystry of the elusive tab. I can't seem to delete the attached image which is no longer necessary. can you help me remove it? thanks
