Where is ArcTutor docmentation?
6964
6
08-14-2011 06:49 PM
YoshiroNagao1
Hell all,
I installed evaluation version of ArcGIS 10 and Geostatistical analyst,
in addition to Tutorial Data 10.
I would like to do the tutorial data ("ArcTutor\\Geostatistical analyst").
Where is the documentation for this tutorial data?
Are the any update for "ArcGIS 9 Using ArcGIS Geostatistical Analyst"?
Thank you very much.
SteveLynch
There is no update for "ArcGIS 9 Using ArcGIS Geostatistical Analyst", it is now contained within the ArcGIS documentation.
The tutorial info can be found in the help or online at
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Introduction_to_the_ArcGIS_Geostatisti...
Steve
YoshiroNagao1
Steve,
Many thanks.
Yoshiro
YoshiroNagao1
Sorry for bothering you again.
I have installed a DVD "ArcGIS Desktop Tutorial Data 10", which completed apparently successfully.
From ArcMap 10, I clicked "Add Data" button and navigated to
C:\ArcGIS\ArcTutor\Geostatistical Analyst, and
double clicked on the ca_ozone.gbd,
following the tutorial documentation.
However, none of "O3_Sep06_3pm" or "ca_outline" datasets can be located.
In the C:\ArcGIS\ArcTutor\Geostatistical Analyst\ca_ozone.gbd folder,
the following files were found:
2010/04/21  15:36             4,440 a00000001.freelist
2010/04/21  15:36               110 a00000001.gdbindexes
2010/04/13  17:09               553 a00000001.gdbtable
2010/04/21  15:36             5,152 a00000001.gdbtablx
2010/04/21  15:36             4,118 a00000001.TablesByName.atx
2010/04/21  15:37             4,440 a00000002.freelist
2010/04/13  17:09             1,515 a00000002.gdbtable
2010/04/21  15:37             5,152 a00000002.gdbtablx
2010/04/21  15:37             4,440 a00000003.freelist
2010/02/17  14:00                42 a00000003.gdbindexes
2010/04/13  17:09             1,696 a00000003.gdbtable
2010/04/21  15:37             5,152 a00000003.gdbtablx
2010/02/17  14:03             4,118 a00000004.CatItemsByPhysicalName.atx
2010/02/17  14:03             4,118 a00000004.CatItemsByType.atx
2010/02/17  14:03             4,118 a00000004.FDO_UUID.atx
2010/04/21  15:36            49,496 a00000004.freelist
2010/02/17  14:00               310 a00000004.gdbindexes
2010/04/21  15:36           538,033 a00000004.gdbtable
2010/04/21  15:36             5,152 a00000004.gdbtablx
2010/02/17  14:03            61,462 a00000004.spx
2010/02/17  14:04             4,118 a00000005.CatRelsByDestinationID.atx
2010/02/17  14:03             4,118 a00000005.CatRelsByOriginID.atx
2010/02/17  14:03             4,118 a00000005.CatRelsByType.atx
2010/02/17  14:04             4,118 a00000005.FDO_UUID.atx
2010/04/21  15:36             4,440 a00000005.freelist
2010/02/17  14:00               318 a00000005.gdbindexes
2010/04/13  17:09               541 a00000005.gdbtable
2010/04/21  15:36             5,152 a00000005.gdbtablx
2010/02/17  14:00             4,118 a00000006.CatRelTypesByBackwardLabel.atx
2010/02/17  14:00             4,118 a00000006.CatRelTypesByDestItemTypeID.atx
2010/02/17  14:00             4,118 a00000006.CatRelTypesByForwardLabel.atx
2010/04/21  15:37             4,118 a00000006.CatRelTypesByName.atx
2010/02/17  14:00             4,118 a00000006.CatRelTypesByOriginItemTypeID.atx
2010/02/17  14:00             4,118 a00000006.CatRelTypesByUUID.atx
2010/04/21  15:36             8,536 a00000006.freelist
2010/02/17  14:00               602 a00000006.gdbindexes
2010/04/21  15:36             2,443 a00000006.gdbtable
2010/04/21  15:37             5,152 a00000006.gdbtablx
2010/02/17  14:00            12,310 a00000007.CatItemTypesByName.atx
2010/02/17  14:00             4,118 a00000007.CatItemTypesByParentTypeID.atx
2010/02/17  14:00             4,118 a00000007.CatItemTypesByUUID.atx
2010/04/21  15:36             4,440 a00000007.freelist
2010/02/17  14:00               296 a00000007.gdbindexes
2010/04/13  17:09             1,764 a00000007.gdbtable
2010/04/21  15:36             5,152 a00000007.gdbtablx
2010/04/21  15:36             4,440 a00000009.freelist
2010/02/17  14:01               116 a00000009.gdbindexes
2010/04/13  17:09            27,584 a00000009.gdbtable
2010/04/21  15:36             5,152 a00000009.gdbtablx
2010/02/17  14:01            16,406 a00000009.spx
2010/04/21  15:36             4,440 a0000000a.freelist
2010/02/17  14:02               116 a0000000a.gdbindexes
2010/04/13  17:09             3,805 a0000000a.gdbtable
2010/04/21  15:36             5,152 a0000000a.gdbtablx
2010/02/17  14:02             4,118 a0000000a.spx
2010/04/21  15:36             4,440 a0000000b.freelist
2010/02/17  14:03               116 a0000000b.gdbindexes
2010/04/13  17:09            13,159 a0000000b.gdbtable
2010/04/21  15:36             5,152 a0000000b.gdbtablx
2010/02/17  14:03             4,118 a0000000b.spx
2010/04/21  15:36             4,440 a0000000c.freelist
2010/02/17  14:03               112 a0000000c.gdbindexes
2010/04/13  17:09             2,458 a0000000c.gdbtable
2010/04/21  15:36             5,152 a0000000c.gdbtablx
2010/02/17  14:03             4,118 a0000000c.spx
2010/04/21  23:07             4,440 a0000000d.freelist
2010/02/17  14:03                70 a0000000d.gdbindexes
2010/04/13  17:09               283 a0000000d.gdbtable
2010/04/21  15:38             5,152 a0000000d.gdbtablx
2010/04/21  15:36             4,440 a0000000e.freelist
2010/02/17  14:03                66 a0000000e.gdbindexes
2010/04/13  17:09             2,316 a0000000e.gdbtable
2010/04/21  15:36             5,152 a0000000e.gdbtablx
2010/02/17  14:03             4,118 a0000000f.blk_key_index.atx
2010/02/17  14:04             4,118 a0000000f.col_index.atx
2010/04/21  15:36             4,440 a0000000f.freelist
2010/02/17  14:03               240 a0000000f.gdbindexes
2010/04/13  17:09           356,104 a0000000f.gdbtable
2010/04/21  15:36             5,152 a0000000f.gdbtablx
2010/02/17  14:04             4,118 a0000000f.row_index.atx
2010/04/21  15:36             4,440 a00000010.freelist
2010/02/17  14:03                86 a00000010.gdbindexes
2010/04/13  17:09               657 a00000010.gdbtable
2010/04/21  15:36             5,152 a00000010.gdbtablx
2010/04/21  15:36             4,440 a00000011.freelist
2010/02/17  14:03                66 a00000011.gdbindexes
2010/04/13  17:09             2,110 a00000011.gdbtable
2010/04/21  15:36             5,152 a00000011.gdbtablx
It seems to me that the files in DVD were not adequately extracted..?
Futher assistance would be appreciated.
Yoshiro
PavanYadav
Hi Yoshiro,
In ArcCatalog or ArcMap, navigate to the tutorial folder and you will be able to see tutorial files.
The tutorial data is stored in a file geodatabase. If you open the geodatabase using windows explorer you will see encrypted files that make feature class(es) and raster(s). I would recommend that you don't open a File Geodatabase using Windows Explorer. Because, if you accidentally delete any files there. Your database will get corrupted. When you access the data from ArcMap/ArcCatalog, you will see these files:
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
YoshiroNagao1
I navigated through ArcMap 10, as you suggested, and following the Tutorial document.
However, I found nothing in ca_ozone.gbd.
I will ask the ESRI in Japan.
Thanks again.
YoshiroNagao1
Everything worked fine.
Thanks.
