Problem with GA Layer Export to Raster
4058
04-16-2014 03:17 AM
TerryBonine
Hope someone can help me.  Using ArcGIS 10.2 and the Geostatistical Analyst, I have generated several kriged surfaces and have attempted to export them to raster using the Data --> Export to Raster command.  When I do this I see the "working circle" for a few seconds and then nothing.  The GA Layer to Raster window does not appear.  Interestingly, when I export the kriged layers to vector using the Data --> Export to Vector command, the GA Layer to Contour window appears and works perfectly.  What have I missed?
Thanks a bunch in advance for your help.
TB
SteveLynch
What happens if you launch the GA Layer To Grid geoprocessing tool (Geostatistical Analyst tools-> Working with Geostatistical Layers) ?
What OS are you running?
Steve
TerryBonine
Thanks for your quick reply -- the GA Layer To Grid geoprocessing tool works perfectly.
I am running Windows 7 Home Premium edition, SP1.
Thanks again,
TB
