Ordinary Kriging_Serious Application Error
6620
20
02-08-2011 10:35 AM
SilviaBologna
I'm attempting to perform ordinary Kriging using the geostatistical wizard in ArcMap10 on Windows Vista SP1.
In particular, in the second step in which I define the Kriging and output type, when clicking  NEXT ArcMap closes with the message "ArcGIS Explorer has encountered a serious application error".
Any suggestions on how to solve this issue?
Thanks
Silvia
SteveLynch
- Can you reproduce the problem, i.e does it happen each time you try?
- Have you applied Service Pack 1?
- Are you using a joined field?
- Can you send the data?
Thanks
Steve Lynch
ESRI
SilviaBologna
Yes I applied service pack1 and I'm using a not joined field of a point feature class of a personal geodatabase.
Actually the error occurs just when I am using this dataset, otherwise, with other datasets I can perform it without any problem.
Thanks
Silvia
SteveLynch
Please can you email me the p-geodatabase ([email protected]) and for the time being copy the featureclass to f -geodatabase or shapefile.
Thanks
Steve
IanJohnson
Hi Hedera and Steve,
When you've reached some type of consensus on this would you please post it? I came on here to start a thread on this exact problem. I am currently running SP1 as well. Not joining to any fields.
I have experienced this same crash when doing ordinary or universal kriging. It always happens on either "Step 2 of 5" or "Step 3 of 5" when using the wizard. The I have emailed my error reports and have included my email with these reports. If it would help you Steve I can send you the address that the error reports are registered under.
Any help much appreciated!
GrizJohnson
SteveLynch
GrizJohnson
What format are you data that cause the crash? I.e p-geodatabase or f-geodatabase or shapefile?
Thanks
Steve
IanJohnson
I am working out of a personal geodatabase.
SteveLynch
We have a problem with some p-geodatabases in ArcGIS Geostatistical Analyst in version 10. Please convert your data to f-geodatabase (or shapefile).
We are hoping to have a fix available post version 10 Service Pack 2.
Sorry for the inconvenience
Steve Lynch
ESRI
IanJohnson
Steve Lynch
ESRI
Hi Steve,
I have been working out of a F-GeoDbase per your suggestion and GeoStatistical Analyst has been working perfectly. Thank you.
Ian
TimCushman
I'm having the same GA crashing problem, but I have been using a joined field? Why can't you use a joined field?
