Emerging hot Spot Analysis results under Visualize Space time Cube in 2D.
2233
04-23-2022 10:44 PM
Lacin_Ibrahim
What's the difference between looking at Emerging hot Spot Analysis result vs Visualize Space time Cube in 2D when Emerging hot Spot analysis result is chosen for the display theme. I get different results, some certain area changes from no pattern to persistent hot . Is it different because I ran the Emerging hot Spot Analysis more than once with different parameters (with different  global window).
EricKrause
Hi @Lacin_Ibrahim
The Visualize Space Time Cube in 2D tool will re-create the most recent result of Emerging Hot Spot Analysis for the analysis variable.  If you rerun EHSA on the same variable, the Visualize STC in 2D tool will start creating the output of the most recent EHSA tool run.
Please let me know if you have any other questions or need any clarifications.
-Eric
EricKrause
Hi @Lacin_Ibrahim
-Eric
Lacin_Ibrahim
That makes sense now, thanks.
Is there any little more detailed source for the Define global window parameter ? I don't get why the neighborhood time step (NTS) and individual time step results are different since NTS is set to 1. I assumed value assigned for the NTS will be the phases.
For a background for my question: I am looking at a daily data for mobility patterns. I believe choosing entire cube gives me the general idea about the patterns for the whole study area. Since, my study area is a large one and have many clusters in it, I am hoping to see the neighborhoods relations by NTS or Individual time step window also.
Thanks again.
LaurenGriffin
Check out this video on Emerging Hot Spot Analysis. It visually describes the differences between each of the Global Window choices, and also discusses the differences in the results (and when one option might be better than another). https://www.youtube.com/watch?v=9VDRYBvOoDI&list=PLGZUzt4E4O2LuV0vuH74WN6j9nxv0jUty&index=5
It's one of 5 videos associated with this learning path: https://learn.arcgis.com/en/paths/spatio-temporal-analysis-of-covid-19-daily-confirmed-cases/  I hope this helps!
Lauren
This presentation was originally given at a workshop in partnership with University Consortium for Geographic Information Science (ucgis.org). For the first time in history, we are experiencing a global pandemic and analyzing it as it happens. Because the spread of any infectious disease occurs ...
