Densify Sampling Network
2694
05-31-2012 03:52 PM
SimonHarper1
  I want to use the Densify Sampling Network to show the optimum locations to position 10 new sites based on a reduction in the standard error.  However I want to constrain the analysis to an irregular area (shapefile/raster). How do I do this?? I figure you either have to modify the geostatistical layer or change something in the Environments tab?
Cheers,
Simon
SteveLynch
Simon
Create a Weight raster, 0 (or NoData) exclude and 1 to include.
Steve
SimonHarper1
Hi Steve,
  I'm quite new to this so bear with me.  I understand the reason for making a weight raster but not sure how to tell the densify sampling network toolbox to you use it.  Do you specify it under the Environmental settings>raster analysis>mask??? or do I specify it under the processing extent??
Cheers
SteveLynch
Please see the image.
[ATTACH=CONFIG]14934[/ATTACH]
SimonHarper1
wow that was super quick...thanks
