cokrigig (cannot initialize method) problem
1008
06-29-2011 01:40 AM
ReşatAkgöz
Hi;
I have an precipitation point and DEM 50m cell size. When I try to do cokriging from Geostatistical analyst, getting tihis respond (connot initialize method). Cokriging process Im selecting point as a dataset 1, selecting DEM as a dataset 2.
What am I doing wrong or am I skip same process?
in addition Im using same projection on each dataset.
Resat
EricKrause
We support cokriging with raster and point input, so I'm not sure why the method is failing to initialize.  Most likely, it has to do with your specific data.
If you can send the data to [email protected], I'll try to figure out why the method isn't working for your data.
