Cannot determine range and sill parameter values from GA model
927
07-08-2011 03:47 PM
ChrisBater
Hi, I am trying to iterate through some feature classes with z-vaues and determine the variogram parameters for each. For each feature class, I create a temporary geostatistical layer using a previously generated model in xml format, then I try to get the nugget, number of lags, lag size, range and sill from the new layer's xml data. Oddly, I am having no problem getting the first three parameters, but then my code fails to retrieve the range and sill.
Any suggestions would be greatly appreciated.
Chris
Here is the code:
#the geodstats model was created manually using the geostatistical analyst wizard
geoStatsModel = r'C:\temp\Kriging2_modified.xml'
#GN1 is a fgdb feature class and 'RASTERVALU' is a field of z values
inData = 'GN1 RASTERVALU'
#create the new geostats layer
arcpy.GACreateGeostatisticalLayer_ga(geoStatsModel, inData, "outCgLayer")
#now get the model parameters
xmlPath = "/model[@name = 'Kriging']/model[@name = 'Variogram']/value[@name = 'Nugget']"
nugget = arcpy.GAGetModelParameter_ga("outCgLayer", xmlPath)
print 'Nugget: ',nugget
xmlPath = "/model[@name = 'Kriging']/model[@name = 'Variogram']/value[@name = 'NumberOfLags']"
lags = arcpy.GAGetModelParameter_ga("outCgLayer", xmlPath)
print 'Number of lags: ', lags
xmlPath = "/model[@name = 'Kriging']/model[@name = 'Variogram']/value[@name = 'LagSize']"
lagSize = arcpy.GAGetModelParameter_ga("outCgLayer", xmlPath)
print 'Lag size: ', lagSize
#code fails here, won't retrieve the range or sill
xmlPath = "/model[@name = 'Kriging']/model[@name = 'Variogram']/value[@name = 'Range']"
rnge = arcpy.GAGetModelParameter_ga("outCgLayer", xmlPath)
print 'Range: ', rnge
xmlPath = "/model[@name = 'Kriging']/model[@name = 'Variogram']/value[@name = 'Sill']"
sill = arcpy.GAGetModelParameter_ga("outCgLayer", xmlPath)
print 'Sill: ', sill
SteveLynch
ChrisBater
Ah I see. The lines to retrieve the range and sill should have read:
xmlPath = "/model[@name = 'Kriging']/model[@name = 'Variogram']/model[@name = 'VariogramModel']/value[@name = 'Range']"
xmlPath = "/model[@name = 'Kriging']/model[@name = 'Variogram']/model[@name = 'VariogramModel']/value[@name = 'Sill']"
Thanks for your time,
Chris
