Geoplanner: Data Layers Grouping
2024
03-06-2023 03:06 PM
MatthewBauer93
I'm building out a Geoplanner project and for the life of me I can't figure out how to group my data layers in order to make it more organized for my customer. At 22:58 of this video - https://www.youtube.com/watch?v=6LFYUjTQ3rs, it appears that there is a group called Big Bear Endemic Species Cores in the Data Layers section. Can anyone explain to me how to accomplish this? I've tried everything I can think of without any luck. Thank you!
Tags (1)
jos20
by Esri Contributor
Hi @MatthewBauer93, GeoPlanner does not support grouping layers. I checked for data layers that have a drop-down arrow like the Big Bear Endemic Species Cores layer you referenced in the video and I found that the drop-down arrow exists because that data layer contains features with different geometries. For example, a polluted waters layer could contain line features for streams and polygon features for lakes.
jos20
by Esri Contributor
MatthewBauer93
Hi @jos20 , I was worried that may be the case. Thank you for confirming that!
jos20
by Esri Contributor
@MatthewBauer93spoke to a colleague and the geometry might not be the culprit. I believe groups created in ArcGIS Online should be supported in GeoPlanner, but we're looking at a potential issue with that.
I've also logged an enhancement in our backlog to learn whether grouping layers can be supported in the future.
