XML input connector - 10.3.0
2588
09-15-2015 06:23 AM
LloydLochridge
I fail to find a XML adapter in the "Add Input" selection.  We are at the 10.3 product release.  Is it out there somewhere?
RJSunderman
Lloyd -
If you navigate to Site > GeoEvent > Connectors and search for "XML" ... you are not seeing the following two inbound connectors?
These should be out-of-the-box at the 10.3.0 release.
What do you see when browsing to the URL https://localhost:6143/geoevent/manager/version.txt
(You should see the product version 10.3.0.4322)
Are you able to locate the XML adapter's JAR file (xml-adapter-10.3.0.jar) down beneath the framework?
  • C:\Program Files\ArcGIS\Server\GeoEvent\system\com\esri\ges\framework\adapter\xml-adapter\10.3.0
- RJ
