Working with GeoJSon
3972
06-17-2014 04:19 AM
ChristopherThompson
I have an input that reads a GeoJson feed from a source and initially I want have that output to a REST cache.  The geoevent definition has the fields organized as groups - features, geometry, properties, and coordinate system.  However, the output doesn't appear to be parsing the several fields into these groups and is creating output that looks like the following:
[INDENT]GeoJason_IncidentPoints,Feature,,,"0.0,0.0,0.0"[/INDENT]
I had thought GEP would parse the fields contained in the groups - is this not the case?
RJSunderman
Hello Christopher -
The Wikipedia article [url=http://en.wikipedia.org/wiki/GeoJSON]here[/url] gives a good example of different types of geoJSON. The GeoEvent Processor is able to parse and accept geoJSON containing "Point" data using the out-of-the-box generic JSON adapter. GEP cannot ingest "LineString" or "Polygon" geoJSON at the 10.2.x release.
Can you indicate the URL you are using to query the GeoEvent cache for data? I think the formatting you are looking for is part of the standard REST API query syntax.
For example, you might post the following geoJSON to a �??Receive JSON on a REST endpoint�?? inbound connector:
    "type": "FeatureCollection",
    "features": [
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    102,
                    0.6
            "properties": {
                "prop0": "value0"
You could then direct the constructed GeoEvent to a �??Publish GeoEvents on a REST endpoint�?? output. At the 10.2.2 release, if you click to open an existing event cache output and review its configuration, you will see links for viewing the cache�??s contents as either �??Text�?? or �??JSON�?? as shown in the following illustration:
[ATTACH=CONFIG]34970[/ATTACH]
(Click to enlarge)
If you browse to the cache�??s REST endpoint and append the formatting f=text you will get the following:
Generated-GeoJSON-Example,Feature,"{""type"":""Point""}"," {""type"":""value0""}"
If you browse to the same endpoint and append the formatting f=generic-json you will get a representation of the GeoEvent matching the illustration below.
[ATTACH=CONFIG]34971[/ATTACH]
Hope this information helps -
RJ
