Waze data stops flowing at filter processor after Geoevent Srver Update 10.9
2462
06-08-2021 04:25 AM
RobertSpál1
Hi Geonet!
We have upgraded our GeoEvent to 10.9 recently and as a result the data flow stopped at the level of the filter processor. We haven't touched any settings or properties of the whole service or definitions or etc. Unfortunately, the documentation does not say anything about this and if I check filter processor settings it is set up as the documentation says. Have any of you encountered a similar problem?  A restart of service did not work. Thanks a lot!
Rob
EricIronside
Hey @RobertSpál1
At 10.9 we have unfortunately found an issue with the filter elements not working with the built in tags for definition name, owner, etc.  One workaround is to use a field calculator to assign the GeoEvent Definition Name to a text field and then filter on that field name.  Another workaround until we can get a fix out is to filter for a field that exists in one event but not in the other event.
Sorry for the inconvenience
Eric
EricIronside
Hey @RobertSpál1
Eric
RobertSpál1
Hi @EricIronside
Thank you a lot for your help! Much appreciated.
Take care
Rob
