Tracking Live data
5969
08-23-2014 02:16 AM
HaniDraidi
Hello all,
I want to establish a live connection between my server (has ArcGIS desktop, ArcGIS Server, Tracking Analyst Extension) and other devices that can determine location like data collectors in the field (using GPS devices with ArcPad) or taxi-drivers using their smartphones, so I can view their current location on a map on my machine. How can I do this?
Thanks a lot
Hani
JakeSkinner
Esri Esteemed Contributor
First, you will want to make sure that you have the ArcGIS GeoEvent Processor installed.  If you don't, I would recommend contacting your Account Manager.  They should be able to provide your with an evaluation copy.  Once you have it installed, I would recommend starting with the following tutorial:
http://www.arcgis.com/home/item.html?id=265c334a47994dcc95e1bd57cf20e98e
JakeSkinner
Hi Hani,
You will want to take a look at GeoEvent Process Extension for Server:
GeoEvent Extension | ArcGIS for Server
HaniDraidi
Thanks a lot Jake,
You are right! It seems that Geoevent Processor Extension is the most powerful engine to handle this process, but I cannot start with it, I referred to tutorials in this link http://www.arcgis.com/home/group.html?owner=GeoEventTeam&title=ArcGIS%20GeoEvent%20Processor&sortFie..., but I did not understand the workflow or the concept of the process and how to make it work. Could you please elaborate a bit more regarding this issue?
JakeSkinner
HaniDraidi
jake,
Thanks you very much for the help, I'll contact the Account manager, and try this tutorial!
Thanks again,
