TAIP0xF0 DeviceId
4193
7
04-30-2014 10:13 AM
AnanthPalani
I am using TAIP adapter to process Sierra Wireless GX440 modem TAIP RPV messages. When I see the text output I do not see the DeviceId. Does the adapter parse DeviceId?
AP
RJSunderman
Hello Ananth -
Yes, looking at the TAIP0xF0 GeoEvent Definition, the DeviceId is being retrieved from the event payload by the adapter. In fact it is being used as the TRACK_ID.
What output are you using to review the event data? Are you receiving the other fields (TimeStamp, Shape, Speed, Heading, Source, and Age)?
- RJ
AnanthPalani
Thanks RJ for a quick response. I am using tcp-text-out and I see Time, Lat, Lon, Speed, Heading, Source, Age but not deviceId.
Best Regards
AP
RJSunderman
Ananth -
Thank you for the sample TAIP / RVP data and references you sent. It appears that the SierraWireless mobile gateway configuration utility - the "ACE Manager" - allows an optional TAIP ID to be specified on its GPS page.
We will see what we can do to to extend the sample TAIP conector to: 1) Determine if this parameter has been included in the broadcast data; 2) Place the TAIP ID, if found, into the DeviceId field of the GeoEvent as a String.
I will follow-up with you as soon as possible. Thank you in advance for your patience.
- RJ
VladislavPlechnoy
Ananth,
I have a build of Trimble TAIP Adapter bundle for GeoEvent Processor enhanced with DeviceID reported from the modem.
Please find it attached to this post.
I would like you to field-test this update for us and provide a feedback if enhancement works as expected.
I will then update our public forum page and GitHub repository with related changes.
Vlad.
AnanthPalani
Vlad & RJ
Thanks for a quick turnaround. It works. I see the Vehicle ID we configured coming in.
Thanks again
Best Regards
AP
VladislavPlechnoy
Ananth,
Please keep us posted if you discover any issues as you are field-testing TAIP adapter.
Your feedback is highly appreciated.
Vlad.
AnanthPalani
Sure will do. Thank you all.
Best Regards
AP
