Simulator: Geometries are OK but all null attributes
759
08-06-2013 05:42 AM
GregYetman
I have set up a service that roughly follows the GeoEvent tutorial but uses my own data. The Geometries (points) are read in fine, but none of the other attributes come in. After I run the simulator, there are a lot of new GeoEvent Definitions created with names that look like they are coming from the values in my .csv file.
I suspect that the service is not using the GeoEvent definition I created and instead is creating one on the fly for each record it is reading.
Any suggestions?
Greg
RyanElliott
I think your guess is exactly right.  The input is not using the GeoEvent definition you created.
  • Go to the Inputs tab in the Manager web pages.
  • Click the edit button (looks like a pencil) next to the name of your input.
  • Expand the Advanced section.
  • Make sure the radio button next to "Incoming Data Contains GeoEvent Definition:" says "No".
  • Next make sure "Create Fixed GeoEvent Definitions:" is "No".
  • Now make sure the "GeoEvent Definition Name" has the geoevent definition you created.
  • Click the Save button
This should start creating the right type of geoevents.
Unfortunately you will have to delete all those other definitions (hopefully there isn't too many).
GregYetman
I had used the wrong name in the definition, that did the trick. Thanks!
