Rest Port
2790
04-01-2014 07:19 PM
DarrylWilson
Hi there,
I note that the default GEP Rest End point Port is 6180.
Is there anyway of changing this?
Best Regards
Darryl
MarkBramer
Hi Daryll,
Check out C:\Program Files\ArcGIS\Server\GeoEventProcessor\etc\org.ops4j.pax.web.cfg.  Just open it with a text editor, modify the ports, then restart GeoEvent Processor.
Hope this helps...
Mark
RJSunderman
Below is a list of ports used by the GeoEvent Processor which identifies the configuration files you can use to change the defaults.
(Click thumbnail to enlarge / open in a new window)
[ATTACH=CONFIG]32748[/ATTACH]
