Input connector for TCP Socket
2892
10-02-2013 06:29 AM
MarkWells
We are writing an application that receives real-time data on a TCP socket in Base64 transfer encoding for MIME (RFC 2045).
The TCP socket connector included with GeoEvent Processor appears to process text only. Does that mean I'll need to write my own input connector for Base64 encoding?
Mark
RyanElliott
Yes, it looks like you will need to have some custom work done to support this.  The built in connector is a combination of a regular TCP socket Transport and a UTF-16 based Adapter (parser).  The Transport hands raw bytes to the Adapter for parsing.  Since the Base64 decoding process converts bytes to bytes, you could potentially swap out our built-in Transport or Adapter depending on which one you wanted to preserve.  For example, if you think the built-in Adapter is really nice, you could write your own TCP transport that automatically decoded the bytes.  Or you could use the built-in TCP Transport and write your own custom Adapter to decode the bytes and convert them to GeoEvents.  Either way, there are code samples in the SDK showing how to write a custom Transport and Adapter.
MarkWells
great, thanks for the confirmation.
