Import GeoFence changes string value which causes Field Enricher to not work
1519
07-29-2013 12:05 PM
JohnGrayson
Esri Alum
Import GeoFence changes string values by adding underscores for spaces (and other characters) which then causes the GeoTagger to add new field with a string value that the Field Enricher (from the same Feature Service that was used to import the geofences) to not work because the field values no longer match.  Any suggestions on how to workaround this issue?
TimothyStiles
Hi John,
Thanks for your feedback. We currently modify the original values for internal-use by the GeoEvent Processor, yet do not map them back to their source. We will consider this for a future release. Again, thanks for your feedback John.
-Tim
TimothyStiles
Hi John,
The issue has been logged and the team will look into it. Again, thanks for your feedback.
-Tim
