How do you turn off DEBUG in the Logs section
3854
01-03-2014 01:22 PM
DennisGeasan
I managed to turn 'DEBUG' on in the Settings section of the "View Log Messages page but I can't see how to turn it off.  Every log message 'Level' is DEBUG.
DG
RJSunderman
From GeoEvent Processor Manager:
  1. Select 'Logs' to switch to the 'View Log Messages' page
  2. Click 'Settings' to display the 'Log Settings' dialog
  3. Select 'Trace' for 'Log Level'
  4. Select 'ROOT' for 'Logger'
  5. Click 'Save'
This should reset your GeoEvent Processor logging to a non-verbose level.
RJSunderman
Completely misstated - apologies.
You should set the logging level to 'INFO' for 'ROOT'  (not 'TRACE') in order to reduce log verbosity.
Setting the logging level to 'TRACE' as I suggested turns verbose logging on.
- RJ
DennisGeasan
INFO is also fairly verbose.  It shows the JSON string for every feature being updated in the target feature class.
DG
