GeoEvent Simulator cound not connect
1671
05-09-2018 08:29 PM
Trung_KiênTrần
I could not start GeoEvent Simulator, when I clicked connect button and I had error: Failed to connect to locallhost:5565 - No connection cound be made because the target machine actively refused it 127.0.0.1:5565. I installed GeoEvent Server with the same machine I started Simulator. Please give me a advise. Thank you!
JamesGough1
I found this can happen when the input tcp-text-in service has not yet been started in GeoEvent Manager.  I sometimes will check to see if the port is listening in a command prompt using the command netstat -na | find "5565" or "LIST"
Thank You,
Jim Gough | Technical Lead Enterprise - Educational Services
Esri
