GeoEvent server output connectors do not increment
1919
12-01-2020 01:05 AM
OsamahOthman
I am exploring functionalities in GeoEvent server following the tutorials in Tutorial - Introduction to GeoEvent Server.
The exercise includes simulating flight data using GeoEvent simulator using tcp-text-in input connector and exporting it to GeoEvent logger tcp-text-out output connector. The thing is though the input connector counter increments as stream data is received, the output connector still counts 0 and no output is displayed on GeoEvent logger.
The screenshot attached illustrates the problem.
I tried to inspect the logs, I found multiple RECEIVED UNAVAIVLBLE ADAPTOR message displayed in the log. I can't figure out what I have done wrong or why this in happening.
Another thing is the input connector counter increments only after about one minute of streaming a single record at nearly constant rate no matter how fast the data is streamed. I don't know if this should be the normal case as I expect them to have the same count.
I am really thankful if somebody could help me with this issue.
JosephCarl2
HI OsamahOthman, I am having the same issue on 10.9, federated with portal.  Did you ever get this resolved? I'm contemplating unfederating and starting over.
OsamahOthman
Unfortunately, I had to uninstall the enterprise and reinstall again, It worked fine then.
