Geoevent server 10.7.1 No service was found
2960
12-16-2020 10:16 PM
Hwa_SaupLee
Geoevnt server has been running over year without problem but last week I got "No service was found" in accessing the geoevent manager.
I did following steps but so far no luch:
  • I reboot the server
  • restart services: arcgis server, geoevent gateway, geoenvet server
  • restart zookeeper service (synchronization service)
  • remove content in the geoevent/data
but not working so far.   Any suggestion?
DominicRobergeIADOT
I have the same problem and using arcgis server and Geoevent 10.8. I have been working for two weeks with Tech Support on that and nothing is working. We did an ADMIN reset, and no matter what the Zookeeper status us always UNKNOWN. I also tried to restore the machine backup from the day prior and STILL get the "NO SERVICE WAS FOUND". I guess the last option will be a clean re-install???
Hwa_SaupLee
hmm.  waiting for tech support call.  it is a production server and  I want to avoid reinstall or factory reset.  let you know how it goes.
Hwa_SaupLee
I followed the steps in this document: HowTo:  Administratively Reset GeoEvent Server (10.5.x / 10.6.x) (https://community.esri.com/t5/arcgis-geoevent-server-blog/howto-administratively-reset-geoevent-serv...  The steps for 10.6.x works for my case (10.7.1).
Then the geoevent server manager is accessible but all services are gone because the steps delete all service configurations.     It is important to back up the configuration before you follow the step.  Geoevent services are restored by configuration import and all services are back to normal.
Stefan_Jung
GeoEvent automatically backups the configuration file. Default Location is: C:\ProgramData\Esri\GeoEvent (this is also mentioned in the Blog Post). You can also configure GeoEvent to save the automatic backups to other locations (defined at Site > Data Stores | Registered folders > Automatic Backups).
If you dont have the option to create a backup before resetting this might help.
Best,
Stefan
feralcatcolonist
How did this work out for you? I'm seeing the same issue EXCEPT the service is visible when accessed locally on the GeoEvent Server but does not appear on the outwardly facing end point. And receiving this error.
could not find the configured service "..."
