Cannot use FlightAware in GeoEvent
2053
08-08-2017 03:54 PM
KevinEscalera2
I have a GeoEvent Test Environment with ArcGIS Enterprise and GeoEvent 10.5 installed and working with the default transports and adapters, I want to try FlightAware Connector (which I downloaded from https://www.arcgis.com/home/item.html?id=9a49618c30a54071ab75c69e3f4e6090 )
but after following the steps indicated in the manual for setting the configuration and registering the adapter I notice in the log this warning:
and if I try to create an input the page doesn't load anything but the save and cancel buttons
If I inspect the Web Browser Dev tools I see this:
Any help would be appreciated, I'm really stuck here.
Thanks in advance
GregTieman
Hi Kevin Fernando Escalera Robles,
This is a known issue you're encountering in 10.5.1. The workaround is below:
  1. In GeoEvent Manager, navigate to Site > Connectors.
  2. Locate the Receive FlightAware connector in the list and open its properties by clicking the Edit button.
  3. Without making any changes to the connector properties, click Save.
  4. Navigate back to Services > Inputs and click Add Input.
  5. Locate the Receive FlightAware connector and click Select.
The connector properties should now appear.  Hope that helps!
GregTieman
KevinEscalera2
thanks a lot, that solved the problem, now I can see the interface for the input creation
