Buffer Size
863
01-17-2023 09:41 AM
JohnLucotch2
Good Morning,
I keep getting errors on GeoEvent Server about: Second attempt failed. Giving up. (xxxx/arcgis/help/en/geoevent --- No buffer space available (maximum connections reached?): connect).  Is there away around this as ArcGIS Server just keeps crashing and becomes unavailable until I restart GeoEvent Server?
Ranga_Tolapi
Hi, @JohnLucotch2
We are getting the error No buffer space available (maximum connections reached?): connect, with ArcGIS Workflow Manager Server. Do you have any luck in resolving it? Would you mind to share your solution. Thanks.
