10.3.1 Cumulative Incident Detector acting as Point in Time
2739
03-04-2016 05:37 AM
ImranRajjad
I have configured a cumulative incident detector, It is following the incident location, but the previous location is not being deleted and there is a trail of incidents as if the incident detector was configured as point in time. I have attached the configuration and the result on map. Am I doing something wrong here?
any help will be appreciated. I am actually following the geoevent tutorials.
regards,
Imran
ImranRajjad
Fixed - I had to implement a Field Mapper processor to fix this. Can anyone confirm if its a bug?
ImranRajjad
MaximilianRågmo
Hello,
I have the same problem as described above.
Between what components/geoevent definitions did you implement the Field Mapper processor?
ImranRajjad
Hello
I simply implemented the exact copy of Field Mapper for the definition
