The ability to split incoming data based on groups or geotags seems a fairly standard process-- --especially if you are trying to populate downstream applications with the ability to filter based on a single attribute. Since much of the data streams are outside of a user's control, these processors are invaluable to split up data into a way that is usable within the downstream apps (experience builder, dashboards, etc.) which are not well-designed to ingest multi-categorical data.
Since this tool is already Esri supported, let's add it into the standard installation and allow users to utilize it without the need to install the GeoEvent SDK.
https://www.arcgis.com/home/item.html?id=68238a93e5fd4043ad0bbb501b265566
https://github.com/Esri/field-splitter-for-geoevent
https://github.com/Esri/multi-cardinal-field-splitter-for-geoevent
