Understanding what a GeoEvent Definition is and how they are created is important for understanding the real-time analytics, filtering, and processing being performed by a GeoEvent Service.
In the Making Features Come Alive exercise in Module 2 of the Introduction to GeoEvent tutorial, you are introduced to the Field Mapper Processor. One of your first experiences with GeoEvent Definitions will probably be when using a GeoEvent Service to add or update features in a feature service’s feature layer. Mapping a GeoEvent to a schema consistent with the feature layer before sending an event to an output to add/update features is a recommended best practice.
You should think of every GeoEvent as having an associated GeoEvent Definition. An input connector does not receive GeoEvents. The connector has a transport which receives and hands-off a byte stream to the connector’s adapter. The adapter needs a GeoEvent Definition in order to instantiate different data values and place the data into different fields within a data structure. It’s like the adapter is sorting mail -- this field is a String, that field is a Date, that other field is a Long integer,… etc. The structure of a GeoEvent is specified by a GeoEvent Definition.
Several input connectors available out-of-the-box with the GeoEvent Extension use adapters which allow you to determine whether the adapter should create a GeoEvent Definition. The adapter does this by taking the first event received, examining the data values, and then making a best-first-guess at what the GeoEvent Definition should look like. If a GeoEvent Definition already exists with the name you specified, the adapter will use (not update) this existing GeoEvent Definition.
GeoEvent Definitions have owners. When an adapter creates a GeoEvent Definition for you the owner will look something like: auto-generated/com.esri.ges.adapter.inbound.JSON
If you copy an existing GeoEvent Definition, import a GeoEvent Definition from a feature service, or click 'New GeoEvent Definition' to create one from scratch, the GeoEvent Definition owner will typically be displayed as either arcgis (10.2.x) or admin (10.3.x) depending on how you logged in to ArcGIS GeoEvent Manager.
Only two GeoEvent Definitions come defined out-of-the-box. The incident GeoEvent Definition owner is identified as com.esri.ges.processor/IncidentDetector/xxxx. You can see this if you click to examine the incident GeoEvent Definition. The TrackGap GeoEvent Definition is the other GeoEvent Definition that is defined out-of-the-box. If you click to examine this GeoEvent Definition you will see that its owner is com.esri.ges.processor/TrackGapDetector/xxxx. These owner strings tell you which out-of-the-box processor created the GeoEvent Definitions; the xxxx identifies the GeoEvent Extension release.
Sometimes a processor will modify an event’s structure or schema by either adding or removing a field. When a processor does this, it will create a new GeoEvent Definition. The Field Calculator Processor is a good example; you can configure this processor to place its calculated value into a new field. The Field Enricher Processor is another example; it is taking data from a feature service's table and adding new fields to the event it is processing.
When a processor creates a GeoEvent Definition for you, you are typically required to enter the name the processor should use for the GeoEvent Definition it will create.
It can be important to understand when a processor creates what I have referred to as a managed GeoEvent Definition. A processor will not create a managed GeoEvent Definition until it actually receives a GeoEvent. You have probably discovered that you cannot, for example, configure a Field Mapper Processor which follows a Field Enricher until the Field Enricher has received and processed an event. Once the Field Enricher receives a GeoEvent, it will process the event and create the necessary GeoEvent Definition. Only then can you edit your GeoEvent Service to configure your Field Mapper.
Since processors own the GeoEvent Definitions they create, any change you make to the GeoEvent Service which incorporates the processor will trigger the processor to delete its managed GeoEvent Definition when you publish the GeoEvent Service to save your changes. For this reason, you should be aware of when GeoEvent Definitions are created, when they are deleted, and when they are available for reference by another processor or output connector.
A few recommendations to take away from this quick discussion:
