Open source geospatial data for testing parallel computing
1639
04-13-2023 03:04 AM
shizu6
I am running some tests with Dask GeoPandas but I'd like to run those tests with huge geospatial data. I have been looking around (probably not in the right places) but I cannot find anything that is properly huge. I would love to test Dask GeoPandas with a CSV (or other file type) that contains thousands of geospatial records. The geospatial element could be as simple as having lat and lon columns.
Any help would be much appreciated. Thanks!
VenkataKondepati
Honored Contributor
You’re right — most sample datasets are too small to really put Dask GeoPandas through its paces. A few good, openly available options that work well for large-scale testing:
import dask.dataframe as dd
import dask_geopandas as dg
import geopandas as gpd
from shapely.geometry import Point
# Read multiple monthly CSVs
df = dd.read_csv("yellow_tripdata_2024-*.csv", assume_missing=True)
# Convert lat/lon into point geometry
def add_geometry(pdf):
    return gpd.GeoDataFrame(
        pdf,
        geometry=[Point(xy) for xy in zip(pdf.pickup_longitude, pdf.pickup_latitude)],
        crs="EPSG:4326"
gdf = dg.from_dask_dataframe(df.map_partitions(add_geometry))
print(gdf.head())
That way you can test scaling behavior across millions (or even billions) of rows without having to hunt for obscure “huge shapefiles.”
If you want “massive” benchmarks, OpenAddresses and GDELT are probably the best options, while TLC data is a nice, manageable starting point because it’s already partitioned by month.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
