WPF Mobile application caching ARCGIS Online webmaps.
939
09-13-2011 10:19 AM
BeauElliott
Hey, I'm completely new to ESRI products as a whole and I've been reading alot but I can't determine the best way to accomplish this.
I want to use the ArcGis Online web maps; the street map specifically. I want to install a mobile pre-compiled cache of this street map and I also want to update this cache if there is an internet connection available, but if not, simple use the local cache.
It seems as if I can provide a basemap locally, that doesn't get updated, and mobile cache some other map that I serve up from our ESRI server, but this is not what I want. I want to mobile cache the basemap served up by ESRI's ArcGis online street map.
Is Mobile even the product I'm looking for?
MelindaFrost
According to the license agreement for tiled caches hosted through ArcGIS Online, you can't use them as a layer in an mxd that you plan to publish as your own tiled cache. You can add them in WPF as a TiledServiceLayer and you would need internet connection. If you plan to work disconnected you can use the SDC data stored locally.
