Welcome to the 9.4 Beta Program!
5754
10
10-04-2009 09:11 PM
JeffShaner
All,
Welcome to the 9.4 beta program! The Mobile team is looking forward to hearing from you.
Important notes for getting started with the 9.4 beta:
1. ArcGIS Mobile client applications and SDK are bundled in a separate ArcGIS Mobile setup. They are no longer included in the Server .NET setup.
2. For beta 1 only, the ArcGIS Server .NET setup does not install the web services needed to create and store mobile projects on your web server. You will need to run a separate "ArcGIS Mobile Project Server" setup on your web server to create and manage the projects your field applications will use.
For more details, go to the new 9.4 Mobile resource center. Details will be posted on the blog.
http://resourcesbeta.esri.com/content/arcgis-mobile-94
Mobile team
RichardDaniels
MVP Regular Contributor
So, I'm in the beta program but when I report a bug Customer Support argues with me instead of taking the report and researching the problem. I don't expect a resolution at this time, it is a Beta after all, but I do expect feedback that a report has been documented and someone on the Dev team will look at the issue.
I'm currently using the following process to report issues. If this is wrong let me know.
"To report software bugs or problems related to the application itself, login to http://beta.esri.com/index.cfm?event=main.dsplogin with your ESRI global login, select ArcGIS 9.4 from the �??my beta programs�?? list then select the Contact Support link on the bottom left."
thanks!
