Synchronize Mobile Cache  not successful
3085
04-25-2012 03:28 PM
DorotheaKnigge
We have created a Mobile project for managing collector road assets. The data resides in the SDE and has Global ID's and is set up for attachments. It was created using ArcCatalog Mobile Tools and was successfully loaded onto a Windows Mobile Mesa GPS unit.
The minor testing has gone well and until recently had no problems synching/uploading minor changes and photo attachments back into the database using the Synchronize Mobile Cache Tool in ArcToolbox. The field crew has now taken the unit out to update signs on two roads, however now I am not able to use the Synchronize Mobile Cache  tool successfully.  I have attached the result message.  Does anyone have an idea of what might be going happening?
As a footnote:
Before it was taken out by the road crew I had created a ArcGIS Server web service and also created a web application with editing capabilities using the same database.  I have since deleted the service and application thinking that it might be affecting my mobile project.
Thanks you for any help,
Dorothy
StevenCuthbert
Did manage to get an answer to this? The tool crashes when i try to use it. I'm using Windows 7 64-bit with ArcGIS 10 sp5
