i think you can do that by using two mobile services, configure each one to the tiles you have, and set the map data sources accordingly, to the one you want to get it displayed..
you can do it through code..
let me know if u need any help
i cant find any map property nor method who refers to the map data sources;
if you have tow tild map layers 1-tiledStreetMapLayer 2-tiledSateliteMapLayer and in the beginning the tiledStreetMapLayer is on and you want to change the tield map layer to the tiledSateliteMapLayer this is the solution
