Sketch Graphic Layers Visibility
854
11-04-2011 11:34 AM
JamesStanforth
I have a sketch graphic layer that I use in a mobile project to draw a line between two points. Users want the ability to press a button and toggle the visibility of this line. Seems simple enough but my code is not working:
            Dim sketchLayer As Sketch.SketchGraphicLayer = mobMap.MapGraphicLayers("ATCFLayer")
            If sketchLayer.Visible = True Then
                sketchLayer.Visible = False
            Else
            End If
            mobMap.Refresh()
If I step through the code the visibility property of the graphic layer gets changed but it never actually toggles on/off in the map. It continues to stay visible even with the property set and the map refreshing.
Any tips or descriptions of similar experiences would be greatly appreciated.
-James
