SelectionMapAction SelectionLayers - can selection be constrainted by queryfilter?
651
02-21-2012 10:47 AM
LaureBowman
I have an existing mobile app I've taken over support/development of. It uses SelectionMapAction.SelectionFeatures to perform updates on selected features. The code constrains the selection based on a layer:
selectionMapAction.SelectionLayers.Clear();
selectionMapAction.SelectionLayers.Add(layer);
and then functions are performed on the results using:
selectionMapAction.SelectedFeatures
If there a way in mobile to constrain selection based on a queryfilter for the layer. All features in the layer are visible on the screen, but I want the select to only work on features that have a certain attribute field value.
If this possible and if so, what is the best way to go about this?
Thank you for any suggestions!
