Replace.Delete portion operation
1711
10-06-2011 03:24 AM
MoragHawkins
Hi
Just trying this new functionality. I have created a new feature, and I wanted to test editing it. Few observations:
1) Selecting a feature to edit was not easy, before there was a manage edits task, but I cannot see that now, so I have to use the identify tool in map view, wait an age (this tool identifies all layers in the project, regardless that I only had one layer set to visible, I have about 20 layers), then click on the relevant identify result, then view attributes, then click edit.
EDIT: I see you can also go to the Collect Features task -> Menu -> View Collected Features
2) I tried replace geometry, you cannot cancel out once you have selected this option if you actually want to replace portion or delete portion instead
3) Get erorrs when actually doing a replace geometry, attached.
4) If selecting replace or delete portion, it asks to click using stylus or use gps. If I try using stylus, the pan tool is enabled, cannot be toggled off, and all I can do is pan map, I cannot add geometry via stylus.
