Project Center Crash on Load ArcGIS Server Map Cache
831
02-09-2011 08:17 PM
PeterTimmers
Loading two different compact map caches (imagery and streets) from our server causes the project center to crash.  I'm not getting any message, it just disappears.
I can load "Mobile Caches" constructed in Arcmap but not Server Caches.
Has anyone else experienced this?  Should I push this one to support?
The projection is Web Mercator Auxiliary Sphere.
(Here's hoping 10.1 fixes some more problems)
ChristopherOlsen
I have not seen any issues with using compact caches in Mobile 10.  There was an issue with caches not working if there was a space in the dataframe name, but not using 2 caches.
I would suggest logging an incident with Support if you have not already done so.
Chris
