Plugin HelloworldTask
4409
03-12-2010 11:44 AM
MarcoWagemakers
Does anyone have already experienced with programming a Task as a plugin in the mobile tablet application?
I did unzip the helloworldtask and build it with visual studio.
I copied the result dll to my project folder:
C:\Users\Wagemakers\AppData\Local\ESRI\ArcGIS Mobile\P_Bomen
And add in my project file:
<Task assemblyQualifiedName="CustomizationSamples.HelloWorldTask,HelloWorldTask"></Task>
The Helloworld task is not available in the task list of the project.
Can someone help me?
The ArcGIS Mobile project and Visual Studio project as attachment.
Marco
MarcoWagemakers
The walktrough in the developers help describes to copy the assembly to the plugin folder: "C:\ProgramData\ESRI\ArcGIS Mobile\Plugins\ in case of windows 7.
However, in my computer there is not a plugin folder available.
So I give it a try and copy the dll to another location in the program files bin folder of mobile:
C:\Program Files (x86)\ArcGIS\Mobile9.4\bin*
And it works fine!
(*) (x86) in case of Windows 7 64 bits
Marco
by Anonymous User
Not applicable
Original User: jdou
Hi, Macro
For 94beta2 and later (pre-release, 10 final), the tablet task/extension dll should be deployed to a folder named Extensions, instead of Plugins.
on XP:
-mobile bin folder  or
-C:\Documents and Settings\All Users\Application Data\ESRI\ArcGIS Mobile\Extensions
on Vista, Windows 7:
- mobile bin folder, or
- C:\ProgramData\ESRI\ArcGIS Mobile\Extensions
We used "Plugins" as the folder name in beta1, then changed to "Extensions".  This is an error in the doc, thanks for pointing that out.
-jw
MarcoWagemakers
FYI
After installation of the prerelease there is no folder in C:\ProgramData\ESRI\ArcGIS Mobile\Extensions
Marco
by Anonymous User
Not applicable
Original User: jdou
Hi, Marco
You could create the Extensions folder manually, then put extension dll files there. Mobile setup does not create this extension folder.  we will make this clear in the doc...
thanks
-jw
