MobileWeb JSON format examples
1272
08-31-2011 05:50 AM
JeffPope
I'm trying to get the popups to display some field information from the polygons selected. Any example on how to do this? I found the document explaining how to create a basic JSON but it doesn't explain the popus. Version used is ArcGIS Server10.
GordonSumerling
Hello Jeff,
This is probably the one part of setting up mobile for iOS or Windows Phone that is the least well documented that I have found. However, here is a good example of a JSON with pop-ups
http://www.arcgis.com/sharing/content/items/e90771d06b484f78a1d4fc205f707776/data?f=pjson
I think this is an area where ESRI needs better documentation. If you missing one comma or bracket then the JSON will not work
Cheers
Gordon
JeffPope
Thanks Gordon, that's a great start. I'm noticed that on the iPhone or iPad, when you tap on the map, you get the location information, no matter what polygons are present. Is there a way to configure the popup to display the polygon information when you tap on it?
