Issue with an SDC basemap layer
646
05-03-2010 10:23 AM
deleted-user-T42XKeMY9oXS
I have a streets layer in a windows (laptop) based application. The basemap layer based on a map document(.mxd) that is converted to the basemap using the converter tool.
The problem is this: In the original map document (in ArcMap), the street name (label) renders once per page(as is the desired behavior). But in the mobile application, at the same scale, the label repeats along the line multiple times.
If someone could provide a way to correct this behavior, I would be much obliged.
Ashish
AshishTejnani
If the imported Map Document is in the SDC (Special Data Compression) file format, then it will have to be converted into a File Geodatabase format.
