Is it possible to average GPS points with ArcGIS for Windows Mobile 10.1.1?
3202
04-16-2013 06:40 AM
JamiePetersen
There used to be some point averaging capability within ArcGIS Mobile, but I can't find any documentation or settings regarding averaging in 10.1.1 - is that not a feature anymore?
AkhilParujanwala
I personally am using ArcGIS Mobile 10.0 and I am using the GPSAveragingTool, but in 10.1 things have changed.
Here's a link
http://resources.arcgis.com/en/help/windows-mobile/3.0/index.html#//007v00000024000000
Here's the quote:
Use a single-shot GPS location (a replacement of the GPS averaging method) to capture a point.
I hope this helps.
AkhilParujanwala
Here's a link
Here's the quote:
I hope this helps.
JamiePetersen
This answers my question.  Thank you.
It sounds as if "single-shot" is enhanced collection, but I'm not 100% sure because I couldn't find exact documentation on what exactly "single-shot" means from ESRI.  This artcile describes it pretty well in regard to cellular phones (http://www.gpsworld.com/single-shot-position-11047/).  Again, not sure that it is exactly the same, but it gives some insight.
AkhilParujanwala
I am in the same boat, I don't exactly know what Single-Shot means in terms ArcGIS Mobile. I have also searched for documentation or even code samples but I haven't found anything.
Once I switch to the new SDK, I'm sure there may be an example or I could figure it out.
DarrylSanchez
Hello everyone,
To answer your question.  Yes AGWM in the early versions was capable of GPS averaging, but the programmers took it out.  For what reason I do not know.  Personally, I would like to have both options available for the user to choose.  Anyway, I am using 10.2 and
still there is no capability for averaging GPS points only to collect one point.  For me, I am using Precise Point Positioning to collect myreal-time corrected GPS data at 10cm instead of getting my corrections from WAAS or Beacon (CORS.)  I use a YUMA 2 tablet that
blue-tooth communicates with my GPS receiver in a back pack.
