Installing ArcMobile on Trimble GeoXT
3985
08-31-2010 08:28 AM
ChrisCorwin
I am looking from some documentation on how to install ArcMobile onto my Trimble and set it up since you get a free instance of it with 10. Can someone point me to some information?
Thanks!
Chris
DeniseKing
If you are unable to find the deployment documentation on ArcGIS Mobile Resource Center, http://resources.arcgis.com/content/arcgis-mobile/10.0/about, please contact Support Services and log a support request via Phone, Email, or Chat options via http://support.esri.com/en so we can connect you to an available ArcGIS Desktop/Mobile support analyst that can assist you with this workflow. ArcGIS Mobile team is adding new information to ArcGIS Resource Center so please check back frequently.
Thank you,
Denise
Hongliang
I am also looking for such document to install ArcGIS mobile 10 on Trimble Juno SC. Can someone bring up a link here? I couldn't find it anywhere on ESRI pages. Thanks in advance.
AkhilParujanwala
Do you want to install the out of the box solution?
If so, the installation is actually a cab file.
C:\Program Files\ArcGIS\Mobile10.0\Install (Win XP)
Take the cab file put it onto your GeoXT or Juno SC, via MS Active Sync.
Go onto the mobile device, browse to where you copied the file. Click on the cab file just once and it will install.
You may need compact framework .net 2.0, if you get any errors, during the installation or trying to run arcgis mobile. Google the error and you will be able to find the solutions. Most, if not all solutions have been posted here.
In order to download your project (created from Mobile Project Center) you need to make sure MS Active Sync is set to Internet mode or Network, then download the project and then you can use it.
On youtube there is a video made by Sabine Barrera.
If you have any problems google them and then let us know on the forums.
Hongliang
Thank you very much for your detailed instruction.
