fs_table0_deleted_features
879
07-17-2013 12:19 PM
RobertPfingsten
All,
I have an application that is synchronizing features one-way from a service running on a 10.1 server.  While the mobile app does not directly edit the features we do delete them from the mobile cache to prevent cache bloating.  The problem is if you delete a feature using a FeatureDataReader or FeatureDataTable it moves the feature to fs_table0_deleted_features and once there you can never re-synchronize that feature from the server cache.
I tried removing these features from the fs_table0_deleted_features table using the following code and while the code does not fail it does not remove the rows from the table.
using (FeatureDataTable featureDataTable = fSource.GetDataTable(null, EditState.Deleted, null))
                    foreach (FeatureDataRow row in featureDataTable.Rows)
                        _logger.Debug("Deleting row from deleted features");
                        row.Delete();
                    featureDataTable.SaveInFeatureSource();
                    if (_logger.IsWarnEnabled)
                        foreach (var dataRow in featureDataTable.GetErrors())
                            _logger.Warn("Row was rejected from deleted features, error message: " + dataRow.RowError);
Has anyone run into this issue?  Any advise would be appreciated.
