Error saving a project
1814
05-01-2011 11:25 PM
ChrisGraves
I was wondering if you could assist me with an ArcGIS Mobile issue. A large client of ours is having
problems when saving an ArcGIS Mobile Project (see attachment).
The error did not occur while using a trial licence and has since started when the trial licence
expired and they changed to a permanent licence.
We suggested to restart the ArcGIS som/soc service to pick up the new licence but this has not
solved the issue.
I will attach the log file in a separate post.
Any assistance with this would be greatly appreciated.
Thanks in advance,
Chris
JeffAzevedo
I ran into issue that sounds similar to yours, but it started from changing Mobile and IIS settings opposed to licensing.
I had pathing errors after making some changes to the configuration of ArcGIS Mobile. I fixed it by removing all records of past projects in the 'Mobile\ContentRoot\WindowsMobile\XXXX' location, in my case a folder I had named 'Traffic'. I then republished the projects to the web server, and everything worked.
Make sure you back up everything.
Good luck.
