Enable and Disable Custom Extensions in MPC v3.0
946
10-01-2012 01:20 PM
MattMerrill
I'm trying to determine if custom extensions can be enabled and disabled in Mobile Project Center (MPC) v3.0? I know this could be done in MPC v10 but I can't seem to make it work in v3.0.
I've believe I have the extension deployed correctly, however lack of documentation is making it hard to determine that for sure.
When I first open MPC v3.0 and click on the 'Capabilities' section I see my custom extension listed. I can select the custom extension and see that the xaml page has loaded for it. I can select the "Remove" button and it lets me remove it. However when I click "Add" under the capabilities section I don't see anything. I would expect to be able "Add" back the custom extension. A similar workflow was used in MPC v10 to enable/disable custom extensions. Is there something I need to wire up in code to see my custom extension under the "Add" Capabilities section in MPC v3.0?
Any insight would be great, thanks!
Matt
