Does the Android Beta API run on Honeycomb?
980
09-14-2011 03:00 AM
StephenJames
Hi
Does the Android Beta API run on honeycomb? The following working code fails on a motorola xoom.
This code crashes on honeycomb:
View vw = View.inflate(this, R.layout.fire_annotate, null);
//get a handle to the mapview place holder
LinearLayout placeHolder = (LinearLayout) vw.findViewById(R.id.map_view_place_holder);
map = new MapView(this);
ArcGISTiledMapServiceLayer layer = new ArcGISTiledMapServiceLayer(this,"http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
map.addLayer(layer);
LinearLayout.LayoutParams lp = new LinearLayout.LayoutParams(LinearLayout.LayoutParams.FILL_PARENT, LinearLayout.LayoutParams.FILL_PARENT);
placeHolder.addView(map,lp);
setContentView(vw);
exception is
09-14 20:49:18.410: ERROR/(20457): statfs /mnt/sdcard/ArcGIS failed, errno: 2
09-14 20:49:18.410: ERROR/ArcGIS(20457): Failed to initialize the layer:http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer
09-14 20:49:18.410: ERROR/ArcGIS(20457): java.lang.IllegalArgumentException
09-14 20:49:18.410: ERROR/ArcGIS(20457): at android.os.StatFs.native_setup(Native Method)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at android.os.StatFs.<init>(StatFs.java:32)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at com.esri.android.a.g.a(Unknown Source)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at com.esri.android.a.f.<init>(Unknown Source)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at com.esri.android.map.ags.ArcGISTiledMapServiceLayer.initModel(Unknown Source)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at com.esri.android.map.LayerView.initLayer(Unknown Source)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at com.esri.android.map.MapView$1.a(Unknown Source)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at com.esri.android.map.MapView$1.call(Unknown Source)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:305)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at java.util.concurrent.FutureTask.run(FutureTask.java:137)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1081)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:574)
09-14 20:49:18.410: ERROR/ArcGIS(20457): at java.lang.Thread.run(Thread.java:1020)
EmilStanchev
FWIW, I had the same problem and adding
<uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
to the android manifest fixed the issue.
