data collection WPF
917
04-21-2011 07:17 AM
olivierdev
How does the data collection work using WPF?
I had a look at the Windows forms example, but it seems to be a little different with WPF.
I've got an error running my code.
Any example or sample is welcome.
thanks
MelindaFrost
I assume you asking how to edit in general. I am not sure about the sample you are talking about but here is a code snippet of taking the map click and making a map point and saving to feature layer
private void map1_MouseDown(object sender, MouseButtonEventArgs e)
            if (createPoint)
                System.Windows.Point clickPoint = e.GetPosition(map1);
                getMapClick(clickPoint);
                createPoint = false;
        private void getMapClick(System.Windows.Point clickPoint)
            try
                Envelope env = map1.GetRotatedExtent();
                Coordinate coord;
                //GeoTransformation geoTransform = new GeoTransformation(SpatialReference.Create(3857)); // WGS 1984 Web Mecrator Auxiliary Sphere transformer
                //SpatialReferenceConverter src = new SpatialReferenceConverter(SpatialReference.CreateWgs84SpatialReference(), SpatialReference.Create(3857), geoTransform);
                System.Drawing.Point point = new System.Drawing.Point(Convert.ToInt32(clickPoint.X), Convert.ToInt32(clickPoint.Y));
                    coord = map1.ToMap(point);
                    //System.Windows.MessageBox.Show("map coord" + coord.X.ToString() + " " + coord.Y.ToString());
                saveNewObservation(new ESRI.ArcGIS.Mobile.Geometries.Point(coord));
            catch (Exception ex)
                System.Windows.MessageBox.Show(ex.Message.ToString(), "Map Click Error");
        private void saveNewObservation(ESRI.ArcGIS.Mobile.Geometries.Point point)
            try
                //get feature layer
                FeatureLayer featureLayer = getFeatureLayer("Observations", mobileCache);
                //if still null
                if (featureLayer == null)
                    System.Windows.MessageBox.Show("Could not find feature layer 'Observations' in map cache", "Search Error", MessageBoxButton.OK, MessageBoxImage.Error);
                //create datareader
                FeatureDataTable featDataTable = featureLayer.GetDataTable(new QueryFilter());
                DataRow newFeatDataRow = featDataTable.NewRow();
                newFeatDataRow[featDataTable.GeometryColumnIndex] = point;
                //populate new row with some defatul data values
                newFeatDataRow["OBSERVATIONID"] = "1";
                newFeatDataRow["TYPEID"] = 1;
                newFeatDataRow["STATUS"] = "Active";
                newFeatDataRow["CREATEDATE"] = DateTime.Now;
                featDataTable.Rows.Add(newFeatDataRow);
                //now save edits
                 featureLayer.SaveEdits(featDataTable);
                featDataTable.Dispose();
                featureLayer = null;
            catch (Exception e)
                System.Windows.MessageBox.Show(e.Message.ToString(), "saveNewObservation");
