Custom MapAction?  (9.3.1)
3049
09-27-2010 10:38 AM
DavidMarley
Has anyone ever created a custom MapAction by inheriting from the ESRI MapAction class?  Or better yet, the ZoomInMapAction class?  I have seen a couple posts on the old forum but they only snippets, or are old (9.2).
What I am trying to do is inherit from ZoomInMapAction to create a custom zoom tool with different zoombox color.  I have a related post in this topic here:
http://forums.arcgis.com/threads/13381-Change-color-of-zoom-box-in-9.3.1-Mobile-map-control
Have not had too many responses to that, so now just checking to see if anyone has succesfully created any kind of customized MapAction class.
What I would want to do is something along the lines of this (VERY incomplete - just pseudo code really; I don't know what methods etc. I need to implement to get this to work):
public class CustomZoomInMapAction : ZoomInMapAction
 public CustomZoomInMapAction()
  this.Map.Paint += new System.EventHandler<ESRI.ArcGIS.Mobile.MapPaintEventArgs>(Map_Paint);
 void Map_Paint(object sender, MapPaintEventArgs e)
   e.Display.DrawEnvelope(. . .);
The idea would be to paint my own envelope in the paint event rather than the envelope and other graphics the default zoom tool draws.
I know this is a bit of an obscure question.  I appreciate any tips/suggestions anyone might have.  Thanks.
MaximilianGlas
I have no example iheriting from ZoomInMapAction, but I can give you an short example from another one.
using System;
using System.Windows.Forms;
using ESRI.ArcGIS.Mobile;
using ESRI.ArcGIS.Mobile.Geometries;
using ESRI.ArcGIS.Mobile.MapActions;
using ESRI.ArcGIS.Mobile.MobileServices;
namespace xyz
 /// <summary>
 /// Move a feature by mouse drag
 /// </summary>
 internal class MovePointMapAction : MapAction
  private ToolStripButton _controlButton;
  public MovePointMapAction()
   StatusChanged +=
    delegate(object o, MapActionStatusChangedEventArgs e)
      if (e.StatusId == Activated)
       if (Map != null)
        Map.Focus();
        Map.Cursor = Cursors.Cross;
        if (_controlButton != null)
         _controlButton.Checked = true;
      if (e.StatusId == Deactivated)
       ActionInProgress = false;
       if (Map != null)
         _controlButton.Checked = false;
        Map.Cursor = Cursors.Default;
  public ToolStripButton ControlButton
   set { _controlButton = value; }
  protected override void OnMapMouseDown(MapMouseEventArgs e)
   ActionInProgress = true;
   Map.SuspendDrawing = true;
  protected override void OnMapMouseUp(MapMouseEventArgs e)
   if (ActionInProgress == false && Map.IsValid == false) return;
   Point lPoint = new Point(e.MapCoordinate);
   if (Map.GetFullExtent().Contains(lPoint.Coordinate))
    try
     FormIdentifyNavi lIdentifyForm = ((FormMap) Map.Parent).FormIdentify;
     FeatureDataRow lDataRow = lIdentifyForm.CurrentRow;
     Point lOldPoint = lDataRow[lDataRow.FeatureLayer.GeometryColumnIndex] as Point;
     if (lOldPoint != null)
      lOldPoint.Coordinate = lPoint.Coordinate;
    catch (Exception ee)
     MessageBox.Show(ee.Message, Messages.Error);
   Map.SuspendDrawing = false;
   Map.Invalidate();
  // Properties
  protected override void Dispose(bool disposing)
   base.Dispose(disposing);
  public override string ToString()
   return "MovePointAction";
DavidMarley
Excellent! I will see if I can build on this for a custom zoom action.  Thanks for posting this.
SamanZaidi
excellent. it helped me developing code for custom zoom.
